Just installed some fogs in the grille. Idea courtesy of LanceSlide who's rig is pretty sick. I may black out the grille and bumpers but rockin the bling for now.
Lights are Hella 500 FF (freeform). Got a hidden switch just under the dash.
Had to separate the chrome part and main grille which you have to cut the main mesh out of. Found some 1/4" black powder coated expanded metal pretty cheap to insert from here: Universal Extreme Dimensions Metal Diamond Cut Mesh - Black Grille - 103225 by Extreme Dimensions.
jig saw worked pretty well but you have to file away some excess and I painted the cuts w/flat black spray just to help it blend some. came out pretty clean and def sheds some light on the subject.
