I read through the other posting about how to wire your fog light to come on without headlights. I have an 04 and do not have a fog light fuse in my panel. I am also not ready to start cutting wires in my column. Does anyone have tech specs for a 04 to make the fogs work independly??
Why don't you just hook a toggle switch to the fog lights? I have an 05 and I bought aftermarket fogs and just ran the wires wich is extremely easy to do yourself. I just ran the power wire directly to the battery and not through a fuse.
MOD & Token MINI Owner
There is a post on this forum somewhere......... but I just cant find it. But I know you need to make a jumper of some sort in the main fuse box. This will cause the foglights to be able to be on while the park lights are on. I will keep looking for it because I would like to do this too.
thanks all, I have looked at the other posting, but unfortunetly niether of the suggestions will work on my 04. I'll keep looking
