1 - 2 of 2 Posts
Hi everyone,
I have recently picked up my truck w/50K miles on it (2005 crew cab le). I have extended warranty up to 100K miles on it. I want to change all of the fluids since I don't know how well it was maintained. Oil and tranny fluid I have done last night, changed oil to synthetic and drain and filled tranny fluid w/ Amsoil Nissan J spec fluid.
1) what type of differential fluids do you recommend?? front/rear and capacities?
2) what type of transfer case fluid? and capacity?
Last but not least how do you fill differentials and transfer case? I used to have a 2001 chevy silverado and had to fill through a small fill hole using a fluid pump, is it the same for this truck?
Thank you all in advance,
Nick
1 - 2 of 2 Posts
