I have an 02 Frontier crew cab, 3.3L which I bought a month or so ago. I have a problem that the headlights (& the interior dome when illuminated) flicker constantly and annoyingly when the engine is running. The battery appears fine - no starting problems - and the motor is running OK. Any thoughts on what could be the root cause? Alternator, Grounding, Voltage regulator (does the Frontier have a seperate voltage regulator or is it part of the alternator).
Appreciate any insight that anyone can bring to this problem!
Cheers,
AX
Cheers,
AX
