1 - 20 of 21 Posts
we all have been there or are there, their are some things we need done general maintenance or some other things,
for me im gonna need some shocks soon i patched a oil leak in my pan gotta keep a eye on it in future maybe new pan also my truck loves to ghost rev from 1500 to 2000 and it has a higher idle then normal around 1700 on some days so cleaning the idle air control valve or replacing it in future if it gets bad its not the worst or dangerous, change diff fluid in future and possibly some components with steering "i live in new england so salt and winter is not fun" What do you guys need to do in future?? keep me posted!
Install new gears(4:11).
Need to make pinion depth gauges for install.
Install Lokka locker in front differential.
Install XTP manifold spacer.
Install new intake.
Change steel skids to aluminum skids(on order).
Order cam and crank sensors.
Race Prep.
New stickers for NORRA.
Thanks, I needed to make a list of things I needed to do.
Same with tow vehicle and trailer.
Fixing wise? I'm at 220k and the only thing that it really NEEDED was a low intake manifold gasket, a clutch, a distributer, brakes, steering stops, blower motor resistor, a lightbulb or two, lower radiator hose, sway bar bushings and a coolant flush (plus oil and filter changes)
But I've done a lot more stuff that wasn't needed
whistler that's a serious list, going for aluminum skids cause they are lighter?
finallygotatruck yeah dude gotta keep it hydrated!
Yeah, my truck weighs a ton.
Need to get it done by April for NORRA.
Would have been done a long time ago but have not been able to work on the truck due to illness.
2017 Pro-4X w/Luxury Package
Need to install a 4-cyl diesel and 8-speed ZF auto ;-)
Seriously, I need to do a transmission drain and refill and I'd like to replace my oil pan. Rusted to the point I worry about it.
That sucks man
damn man that sucks hope everything is okay!
sounds mint! and i live in new england and my pan has some rust on it and had a leak smaller than a pin hole i put a bunch of jbweld cold weld on it painted with high heat paint and has been good ever since even though its been a couple months lol. but i would go on ebay man. if you can strike a deal with a pan 50 to 120 coming from a place with no salt and minimum rust you'll be good. i might get one in future.
I plan to replace the alternator belt on the '98 next year, is tight and still squeals a few seconds on start-up, and I'm near the end of the adjustment. It's also 10 years old, might try a 7350 belt instead of the 7355 belt. Belt squealing is not uncommon on these trucks.
I also should get new tires for the '98 next year.
Nothing else planned for my 2 Frontiers.
Discussion Starter · #10 ·
yeah 3 or so months ago i replaced all my belts and 2 pulleys i think and now it squeaks on start up a little bit and some times when its at op temp
Try a Bando # 2355, which is 35.75" (908MM) long. The Gates # 7355 is 36.18" (919MM) long. I always use Bando as they've been an OEM supplier of belts to Nissan for many years and always fit exactly the same as the original belts. Gates and Dayco always seem to run a little longer. You can get the Bando 2355 at Rockauto for $3.01+shipping.
Need to replace an O2 sensor .... do the regular fluid changes before winter. I'm weird and change all my fluids twice a year - before summer and before winter. But I wheel my truck regularly and like to take care of it.
Our off-road club participated in a local "Cars and Coffee" event. I cleaned the Nismo up and she got so many looks ... and the question again and again ... That's a Nissan? ::grin::
Nope, it's a Datsun!
I took really good care of my '00 XE...though I wish I would've replaced the original rear leaf springs. They were def sagging when I sold it w/ 185k.
1998 2WD here. Changed out valve cover gasket today and tightened exhaust manifold. Bought spark plugs to replace this weekend. Yesterday I reinforced the rear bumper supports with some welded gussets (I have 3" body lift so bumper was relocated) I have 245,000 miles or so racked up. I need new rear shocks and need to change out cam chain guides soon. Also need to have AC overhauled. Could use the headliner replaced. I plan on doing all of this by the new year.
Reactions: Cleindian44
1 - 20 of 21 Posts
