Hey, so before posting I checked out all the sticky posts about the subject. I ride a 2016 Nissan frontier PRO-4X and I would like to fit 285/75/16 ...
To echo Whistler...
you responded you intend to do some offroading...
My first lift was a 2" spacer, stock UCAs. CBC every time I looked at dirt or speedbumps at reasonable speed, no droop. So on went the SPC UCAs. nice units, adjustable camber/caster, all teh droop the shocks/steering/CVs will tolerate. Better, but not enough lift (maybe 1" actual lift) so I grabbed some MK84 from Nisstec. Nice units, with a 1" spacer, a solid 3" lift when on the ground. Does well for mild dirt, but I still am limited on droop.
I'm now planning a TS primarily so I can get more than 1.5" droop. The fault lies with stock geometry. Only fix is TS.
If you are going on forest service/fire roads then the truck can do it stock just fine 90% of the time (maybe there'll be some deep wash-outs you have to work around) as fire roads are "maintained"
If you plan on running real trails, abandoned roads, abandoned logging cuts... you need more droop. Lift is great, but droop = traction. Traction = fun. Stilts (lift with no droop aka 'bro stance' ) = all-day winching.
Choice is up to you. Personally, If I had it all to do over again, I'd have gone straight to TS. Glamisdude has a thread on how to TS on a budget. If he's still running his production, ask to get a tophat. With aftermarket UCAs you can manage 10" travel (stock is ~5") You could run ~4" lift on 265/75/16 and have ~4+ " droop even with titan control arms on stock rims and barely have any tire outside of fenders. biggest cost would be front axle shafts. This is where I'll be in next yr along with locked&geared
