Just trying to get quick consensus on others that had mis-drilled diff covers.. such a bummer. I was so hoping to get this on today.
I emailed them, I hope there’s no trouble is all. Man that cover looks soo sweet too! Pulling on my heartstrings!🥺 nonetheless, I had to change fluid anyway since my gears are about broken in. Im hoping the next one will bolt right up, gear oil is getting pricey, even at shop price lol!Well that's no good.. Have you called them ? I would feel sending them these same pics they would send out a replacement,,?
I was personally looking at this exact cover
I think I just happened to get a bad apple, oh well it happens. Man I love the quality besides that definitely tough!Weird. I put one on about a month ago and had no issues. I’m sure Ruff/ORG will make it right.
Looks like two of the drill holes on the bottom are off center to the spot face. Inspection was sleepingJust trying to get quick consensus on others that had mis-drilled diff covers.. such a bummer. I was so hoping to get this on today.
sounds liike that's the caseWonder what the difference is between a m266 and a d44. Bolt pattern?
Maybe. In reading the linked thread, it says that a dana 44 cover has 2 less bolts than a m226. Looking up some D44 covers you can clearly count ten. But the one the OP received has 12.sounds liike that's the case
It’s a tank. Keep us posted.I think I just happened to get a bad apple, oh well it happens. Man I love the quality besides that definitely tough!
Someone sneezed when slelecting the G code. 😆Hello Everyone, it's Angel from OffroadGorilla.com. We are working with the OP and RuffStuff to see what's wrong with this particular cover. There are hundreds of these installed and this is the first alignment issue we have.
Solution is probably as simple as sending a new cover out. We want to determine what the issue is so it doesn't happen again. The bolt pattern is CNC machined so it's very odd that it doesn't fit.
