1 - 12 of 12 Posts
how did you get it out of the dash?
Very nice! Would you say they are as bright as the old lighting? Any problems with the dimmer?
Heath
It is actually better than the stock lights, which when the dimmer fails, stay full bright. That is really good for wearing out your eyes at night/early morning.
My dimmer failed a couple months ago, so when I went to red this weekend, it made it a lot better.
I can't test the dimmer, but these are plenty bright while being very easy on the eyes...
Removal:
1. Remover the steering column cover (5 screws)
2. Remove The lower dash Trim (the one at your knees with the E-brake handle and the Fuse panel cover (2 screws)
3. Remove the Black trim around the gauge cluster (4 screws)
4. Remove the Gauge Cluster (4 screws)
5. Unplug the Cluster connections (3 plugs on my model)
Installation:
Exact opposite of above
so does the 03's have leds or do they have 194 bulbs you can just replace?
Removal:
Installation:
so was it a pain to get out?
Maybe 20 minutes the first time...
I've had it out before, so I was out in 10 minutes or less, reinstalled in about 10 minutes...
Just take your time, keep track of your screws (the steering column screws are different from the rest of the trim screws), and when all else fails, consult the FSM.
It isn't difficult.
1 - 12 of 12 Posts
