Take a break...
...before something really expensive gets damaged.
Thanks! I will try what you suggested. I have read the instructions over and over but I just got stuck on these last three things.Okay before I say anything I recommend Professional installation.
Second starter wire
There should be a set of thinner wires coming off the remote same colors as the thicker starter, accessory and ignition wires. Take the thinner starter wire I forgot the color now, but I think its orange but not a 100% sure and wire it up to a relay use the output wire from the relay and connect that to the other starter wire.
Fuel Injection wire
in the engine bay on the engine itself. Generally somewhere around where the spark plugs are, Should be two wires for each cylinder. Use the wire thats different for each cylinder. You technically use any cylinder, but i usually used the first one.
Immobilizer
i have no idea what you mean by d2d and w2w. But if its the unit that detects the resistance for the key in order to start the remote. Then there is a thin blue wire by its self that comes off the remote start, that gets connected to the immobilizer. Then read the rest of the directions on how to connect.
Disclaimer - these are all based on a DEI install and their units. Still recommend you read your instructions or take it to a professional. This was just to help guide you
