1 - 4 of 4 Posts
I just finished replacing the front & rear door speakers & Sub/amp and everything. Everything works perfect. But the next day I noticed the Air bag light in the dash blinks and stays on while driving. I dont think messing with the radio caused this. What does this mean & what do I do? Is it a fuse, maintanance light to take it to the dealer, or bad air bag? Hopefully its a easy fix. Please someone respond asap. Thanks!
you got to be kidding me... You really need to give SEARCHing a try first. This is not the first NEW thread you've started where a quick search would answer your question.
:crikey:
Here's the process to reset the air bag light (copied from somewhere else on the forum)... I tried it and it works.
If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
1 - 4 of 4 Posts
