Hi - I entered a similar post a couple years back, but though I'd try again, now that I've got my intake plenum off. My idle hops up to 2000 rpm whenever my truck is in gear or when it's rolling in neutral. The only time I have a normal idle is when the truck is stopped and in neutral. I've removed to upper air intake plenum to get at the valve covers and I'm wondering if I should be replacing the idle air control valve and/or sensor. Has anyone run into this problem?
Cheers,
geoff
Cheers,
geoff
