Hey all, I just got into a 2017 SV CC. I haven't had an "aftermarket" system since my '98 Frontier KC, so it's been a few years. I've always gone completely aftermarket. I still have my old Alpine 4 channel amp and would like to get something going. I'd like to use the stock HU this time around. It's clean and I don't want to go all in on a new unit right now. I'd also like to keep the stock speakers. I think they sound pretty good for stock. So, my questions for all of you are:
1. Can the stock speakers handle being powered off the amp if I don't max out the gain on the amp? Or should i keep them on the HU?
2. If I tap the sub into the rear speaker line to control it from the HU, do I need a line out converter to do so?
3. Would it be better to power the sub from the amp and take time to adjust the output perfectly instead of tapping into the rears?
4. Is anyone using JL's 8" microsub, and if so, where do you have it located?
I've always bridged the sub between two channels and doubled up my fronts and rears on the two remaining channels. Also, I'm not a huge super bass guy. I listen to a little bit of everything, but I like clean, crisp highs and mids, with the bass evened out and not over powering.
Thanks guys!
Thanks guys!
