1 - 3 of 3 Posts
So I chipped my factory bedliner and want to repair it. The chip isn't huge and it was definitely my fault (ie not a a defect). I'd like the repair to be as close to the original as possible. Does Nissan offer a repair kit? If not, which one of the do it yourself bedliners has the most similar texture? Has anyone else ever tried to repair the factory bedliner?
Thanks!
im not sure what has the most "similar" in texture to our bedliner, but the easier solution would be to tape off the areas that arent chipped then spray the chipped area with some dupicolor spray on bedliner
personally........the bed liner will probably get chipped some more if you have chipped it already. Im assuming it will be hard to keep it looking picture perfect if your throwing stuff in and out of the bed..........and its a truck, i can take some beating. As far as repair, there are plenty of spray on flat black paints to chose from, even like high heat engine enamel has that rough texture to it which might work.
1 - 3 of 3 Posts
