I plan on lifting my 06 2wd in the next couple months. I'm slowly getting parts. My question is at what height Do I need to start looking into extending brake lines. I plan on going 5" in the front, Spindle and +1" on Blistein Adjustable shocks and 4" in the rear PRG 2" Deaver Leaf and 2" Prg Adjustable Shackles. Should I play it safe and just extend both?
I think I'm just going to run the spindles and add a leaf so I would only have to unclip them. Would the fronts need to be replaced with just the CST Spindle?
I have a similar setup as what you are looking at and I replaced mine with +4" front and rear.
Where did you get yours from?
