I've got a CEL and P0420 code. I'm pretty sure my pre-cat is bad. The O2 readings on the upstream and downstream sensors are nearly identical except at idle. It's got 240,000 miles on it.
Simple enough, buy a new one, install it, take it for a drive and see the readings on the rear O2 are almost flat and the ones up front are peaks and valleys, right?
That was until I tried to take it apart. Everything is rusted solid and the fastener heads round off.
More than likely, I'm going to have to cut things apart.
I decided to stop before I got into a situation where I need to remove the manifold and drill/tap new holes.
I was looking online for a set of headers since the factory manifold looks terrible. I mean, it's an OK piece, for 1950, but there's got to be a better part available. I just can't seem to find it. I see stuff for V6 and 98-00, but nothing for the 2003.
Anyone have any good solutions, preferably one that will improve the exhaust flow.
