1 - 4 of 4 Posts
Couldn't tell ya the exact spot but on 2nd Gens. poppin' out the cup holders will expose the PB switch'n stuff... You will get tired of not being able to run a DVD, BT dial, or enter a POI w/o the PB engaged; people just run a wire to GRD. then to a toggle switch.
btw. Welcome to CF.
edit
Guess I fogot to say I have a 06 cc. I just tried the ground toggle switch. Unless I am not doing it right it's not working. I hooked a switch between a ground point and the wire, flipped it a few times, and nothing. Thks.
Clarions are usually pretty easy, pop a DVD in and when the screen says "Audio Only" flip the switch; and picture should appear if the wires are right.
1 - 4 of 4 Posts
