1 - 8 of 8 Posts
Anyone seen this before? looks like it overheated and melted. What causes this?
320348
320350
320349
I haven't. What year Frontier do you have, and which engine? That doesn't look like the EVAP canister purge volume control solenoid valve that I have on my 2018 VQ40DE engine.
Discussion Starter #3
It is an 08 NISMO automatic. I believe it has the same engine VQ40DE. I have had to change this part about three time now. First time it looked as if it had popped on the side. This time is what you see on the photo. I did buy the newer version of the valve to see if that is the problem.
IMO, it looks like it short-circuited inside the valve. Since you said this is the third time you replaced it, did you get it off of Ebay or a similar site? There are a lot of Chinese counterfeit parts out there trying to pass off as OE and are of poor quality. That's also the old style valve which was discontinued by Nissan a long time ago; the new one has a more powerful actuator for better sealing. If you go to Rockauto, they have SMP/Intermotor # CVS67, which is the newer type vent valve and has a 3-year warranty for $68.
Reactions: Zedbra
It's the vent valve that goes onto the canister. The purge volume control solenoid valve is a different part.
1 - 8 of 8 Posts
