1 - 13 of 13 Posts
I Had to pull off my fuel tank on my '04 Frontier to replace what I originally thought was a bad sending unit and long story short I ended up replacing the entire tankl. Unfortunatly in removing the tank the rubber Evap hose which connects to the vapor canister broke. To add insult to injury Nissan has discontinued the part and it is not available anywhere. Has anyone had experience with this part? At this point I am likely going to replace with molded hose with hose that is not molded since I cannot find a direct replacement.
I haven't had to use one of these in a long time, but they are made just for that. They come in a bunch of sizes, and you might have to look for a bit, but they do work. It just goes inside the hose and doesn't allow it to collapse. The pic is a 12 mm, and it would fit inside a 1/2 hose.
The other thing you can do is just custom make one with fittings and hose. This on is like .79 on rock auto.
You could also use metal brake line (remove the line nuts, of course) and bend it to make the curves and use rubber gas for the straight sections.
Thanks everyone for the help. Went to a local mom and pop parts store and was able to find a replacement. Got the truck up and running nice to have a working fuel gauge. Also took the time to replace the seal on the differential cover since it was leaking like a sieve.
2017 Pro-4X w/Luxury Package
Sorry to hear you now have a fuel gauge that accurately reflects how fast your truck drinks it
Did you replace JUST the sensor and leave he original stock pump there? I'm asking because I have a 2004 4-cylinder with a fuel tank sender error code, even though the fuel gauge works fine.
Discussion Starter · #13 ·
Ended up replacing the tank, fuel pump and sending unit. Taking off the tank was such a pain I ended replacing everything just so that I won't have to do it again.
1 - 13 of 13 Posts
