1 - 7 of 7 Posts
Can someone help me? I have a 2007 frontier 2.5 king cab. The original motor costs more than my truck. Is there any other motor that I can replace it with that’s not so expensive? Thank you.
If picking a used motor from a junkyard is worth more than the truck, its time to retire the truck
Is the truck rotted out?
Sent from my SM-G960U using Tapatalk
The truck is still in great conditions. That’s why I need to fix it but the engine for 2007 frontier the 2.5 one us 2600 Dulles compare to Altima’s and x-terra are really much cheaper
2nd gen frontier and xterra use the same powertrains. A 4cyl for an xterra will work in a frontier. A 6cyl for an xterra will work in a frontier.
Reactions: erturne
If your truck is in great condition (except for the engine), it's worth a lot more than 2600 bucks.
Try looking some more for a used engine - You should be able to find something for less.
What is wrong with it? can it be rebuilt or fix rather than replacing an entire engine. Seems like something short of throwing a rod through the block, most things can be fixed.
Looks like you are in Mexico? Have you checked with a local shop for repairs/rebuilds.
1 - 7 of 7 Posts
