Hi & thanks for any help you can give.
I installed the K&N CAI on my 07 Frontier. I have installed them on the last 4 trucks I've owned with no problems. After the install there were no issues. Maybe two weeks in when driving in traffic & barely accelerating, the rpm's drop under 1500. When I hit the gas to speed up the engine hesitates & vibrates mildly. Is the intake pulling in to much O2. I have checked all connections & O2 sensor. Everything looks good there.
When I turn off the overdrive the rpm increases & the problem goes away.
Is there an adjustment I need to make? Thanks again!
