1 - 7 of 7 Posts
Can I get some feedback on this from you guys? I have an '04 XE and recently found nasty clay-like build up in my radiator. Every sign points to a blown head gasket, even though the truck has never over heated. I have begun the tear down process and have the cooling system off and have ordered all new parts. A mechanic friend of mine brought up the idea that I may have a cracked block. If this is the case I have some options...new block, new engine, and some other stuff. What are your thoughts in a direction and advice. I am a novice mechanic at best but don't have the money to pay someone else to do it, so this will be all me.
I have checked the power steering fluid, transmission fluid, and radiator for leaks. The only other option, that I know of, would be a blown head gasket. Like I said, I am a novice so my knowledge is limited.
So, no coolant system pressure test, compression or leakdown test or sniffer test on the cooling system? In 12-13 years, not knowing anything about the water in your area could be anything.
Have you owned the truck since new? DO you know it's history? Without any kind of tests, I would not simply tear in to an engine like that.
We did an old school compression test. We removed the spark plugs and checked one by one leaving the radiator cap off. When we checked cylinder #2 it shot coolant everywhere. I have not owned the truck since new and don't have much about its history at all. I have not tore the truck down very much at all. It's at 125k miles, so I have just done the timing belt, thermostat, and water pump at this point.
How is rest of truck? I ask cuz with those lowish miles, perhaps your engine was not cared for with regular maintenance. If the rest of your truck is similar*, then you may be looking at just cutting your losses best way you can.
*Think drivetrain, drivetrain fluids, suspension, etc...
The engine compartment looks kind of rough. Being in the Mid-Atlantic area and their use of salt and sand road treatments could have played a big part in that. Unfortunately, I don't believe a new truck is an option for me. I would think that the truck has a lot of life left with some moderate repairs. Showed a mechanic the radiator and hoses. He mentioned the fact that dexcool sludge could be a culprit and that the heads and gaskets may be fine. But wouldn't know for sure until he could do a compression test or inspect the heads.
1 - 7 of 7 Posts
