So i hooked up my efan but its always on with the ignition started. I thi k the ac comp wire is not wired rite. Its wired to the fuse that says AC COMP. That wire should be wired so the fan only come on when ac comp is going. Which leads me to think that AC COMP fuse is always powered when ignition turned on.
At the ac compressor the connector is only one yellow wire. Tap imto that?
Wish i had voltmeter...
Someone did writeup but it was on his 03. I gots me a 08
