1 - 7 of 7 Posts
The electric cooling fan on my '99 v6, 4x4, does not work. Is this a standard part or a factory item? I cant find any mention of it in threads or my owners manual. It has the usual clutch type belt-driven fan as well. I would think it should come on when there is high heat, or any time the a/c is turned on to push more air past the condenser. Any thoughts where to start trouble shooting the problem?
Are you running hot with the AC on ? My daughter has a '98 Pathfinder 4WD (heavier) with same engine as you - in Arizona, doesn't run hot or overheat. She has only the stock fan clutch and its cooling fan.
So I think that electric fan is a band-aid someone threw on to combat an in-town running hot or overheat condition. Such running hot in town is typically linked to bad fan clutch, fan shrouding not intact, thermostat, or cap.
That electric fan - even if spinning - won't do anything at highway speeds anyway, the ram effect of moving fast will cool the radiator. Running hot at highway speeds is typically due to bad radiator, thermostat, or cap.
An electric fan (as well as the belt drive fan with clutch) was used on V6 models with A/C. It is still available from Nissan and runs about $112 from online dealers, not including shipping; it's Nissan P/N: 92120-4S100. Spectra Premium also makes a direct-fit replacement and is P/N: CF23026; Rockauto.com sells it for $54+shipping.
The fan should turn on when the air conditioning is working. If you turn on the A/C and the compressor clutch is not engaging, you will have to fix the A/C system, first; it could be low on freon or something else. If the compressor clutch engages when you turn on the A/C, and the fan does not, you can unplug the fan and do a component test to make sure it works by supplying a power and ground directly to it. If it doesn't turn, you'll need a new electric fan. If it does, then you have some trouble-shooting to do, such as check the fuses, check the relay for the fan, etc.
Thanks for all the input guys. The vehicle is not running hot and the a/c functions perfectly without the fan. The purchase was primarily to tow a boat so I will take all the cooling I can get, especially in South Florida. Need to trouble shoot the issue. Thanks again.
Ok problem was the plastic fan was broken apart at the center so the motor was turning nothing. Replaced with aftermarket but was told it does not turn on with the a/c. Only when the engine is over a certain temp. Install was easy since the NEW RADIATOR install required the entire assembly being dismantled. The radiator was my fault...note to all: never never over tighten the radiator hose clamp. Plastic radiator....yep broke the snout right off. Luckily the radiator was only $78.. so not a huge deal. Live and learn.
Good troubleshooting.
So the electric fan does not immediately engage with the AC system?
Fan is good, relay is needing a ground.
Maybe I replaced the ETR thermo switch in the supply ductfor nothing?
1 - 7 of 7 Posts
