billybob had to replace his throttle body and 06footy traded in his under partly the same conditions. Now mine is acting up.
So today, my belts kept squeaking after a little bit so I left the engine running and sprayed that ***** down inside with just water. THe water was probably luke warm in temperature. I turned it off and went on in to work. I went on to crank it up a few hours later and had check engine light and slip light on. I ran the codes and got 10 different codes. 2119 being one of them, which is TAC Throttle BOdy performance/ range description. One more was throttle body related and the rest were all related to pedal position sensor.
My boss told me to unhook battery and let it reset the position sensor. I did so, and it wiped the codes and the truck ran fine. Up until then I would give it gas and nothing. For a while it had no power on the pedal, then it would rev up to 2500 rpms and you would get barely any power out of the truck. When it reset everything was great; she ran fine. After this point I turned the truck off and cleaned the interior. When I was done and cranked it up to reset my radio the lights were back on. I ran diagnostic again and came back only with the 2119 code, the TAC throttle body performance/range. Tomorrow I'm going to do a 3-step chemical treatment on the fuel injectors, throttle body, butterfly, etc. Any other ideas what this could lead to, guys? Or is the 3-step a likely fix?
