1 - 4 of 4 Posts
I recently purchased a 2007 King Cab 4x4 and using multiple parts found on Ebay added 2.5" front and 3" rear suspension lift. I would like to share my experience with the specific products used and the troubles I encountered.
Front:
-Supreme Suspensions 2.5" front spacers 2 5" Front Leveling Lift Kit 2WD 4WD Pro Fits 2005 2016 Nissan Frontier Xterra | eBay
-Pros- These were my favorite product of the entire project, they went in easy, look good, and provided exactly the amount of lift advertised.
-Cons- Instructions were vague, would have been nice if they included new cotter pins for upper ball joint.
-Rough Country LCA cam bolts Rough Country Lower Control Arm Cam Bolts Fits Nissan Frontier 2WD 4WD 1004 | eBay
-Pros- welded eccentric looks like it will hold up well, Clear instructions.
-Cons- These come with an eccentric washer welded to the bolt head, but do not have an eccentric washer for the nut side, just a smaller standard washer. This may work fine, but it leaves me a little worried about the control arms coming out of alignment under stress.
-Energy Suspension 9.9132G Bump stop Energy Suspension 9 9132G Pair Black Ultra Low Profile Button Style Bump Stops | eBay
-Pros- easy install in UCA using 3/8" drill. Nice Low profile.
-Cons- had to purchase extra 3/8" nuts to get proper spacing.
Rear:
-Spring Force 2" Short Add-A-Leaf Kit with shims 2" Short Helper Springs Add A Leaf Kit for 05 16 Nissan Frontier 2WD 4WD Shims | eBay
-Pros- comes with drive shaft angle shims and 4 leaf retaining bolts (only 2 required but I ended up using 3 because I cut one too short)
-NOTE- If you are planning on adding this AAL, removing your overload spring, and not using the supplied shims, the install will go smoothly, however I wanted to keep the overload spring and use the supplied drive shaft angle correction shims so I required some modifications along with longer U bolts.
-Cons- Vague instructions, Washers should have been supplied for use with shim.
-NOTE- Because I wanted to keep the overload spring AND use the supplied angle shim I had to purchase longer U bolts, washers for spring retaining bolt, and modification to the shim. While I had every thing apart I cut 1/2" spacers (blocks) out of 1/4" steel and added them between the overload spring and shim. With my modifications I think I am right at the limit of the factory shock absorbers (there may be 1" of extension left but that's it).
Overall I think I should have spent the extra $$ on a more reputable AAL kit, but I am happy with it. May attempt a 1" DIY body lift in the coming weeks, any suggestions or anyone think i should leave it where it is? See Before and after pictures attached.
Front:
Rear:
How are you liking that rear AAL I just found that product on ebay and was trying to see how you like it since you actually have it on your truck.
I just bought the 3" front spacer/2" rear block kit from Supreme Suspensions. Thanks for showing me what it's going to look like! I am excited to put it on.
Your going to get coil bucket contact with 3". I know because I had it. I ended up buying SPC uca's. They have an adjustable ball joint. Super easy to change except the rear bolt on driver side. Steering column is in the way. The arms come with a new bolt so just use a Sawzall and cut it. The other 3 bolts came out easy. My truck is an 06 and had about 192k on it when I did the arms. Bolts weren't evendors rusty.
Good luck.
1 - 4 of 4 Posts
