1 - 14 of 14 Posts
I am thinking my Frontier (2010 SE CC 4x4) needs just a slight (maybe 1") lift in the back, just to get the rear end up a little where it belongs.
What's the best way to accomplish this?
Easy or Best? Shackle or block would be the easiest but neither is great although the shackle would be the better evil, better way to go is with an aal but I am really not aware of one that will do an inch, they are going to be 2" +.
do you have a lift already, is so what are you running? if its a single pack AAL I recommend getting a 2 or 3 pack AAL if your taking your truck off road
The simplest way would probably be PRG blocks.
It's fully stock. I don't go offroad much, if anything just tooling through a farmer's field. No serious off-roading.
these things have a gnarly rake stock man, have you thought about leveling?
youd be better off raising the front to have a better chance of clearing feild obsticles
not telling you what to do, just throwing it out there
post pics....should be 1" higher in the back than the front already. Would look ridiculous any higher than that without some lift in the front.
1 - 14 of 14 Posts
