81 - 86 of 86 Posts
Discussion Starter #81
I finally got a chance to bring the M226(DANA 44 variant) axle housing to the sand-blaster today. It took him no-time to blast it($40 worth). Back at home, I cleaned it and applied two good coats of primer.
When I get time, I'll fab a differential protection plate before assembly.
Discussion Starter #83
Pinion shaft nut, crush sleeve, pinion shaft seal and axle shaft seals arrived today.
Axle shaft bearings arrived yesterday. Now I need to find time to begin assembly of the M226 locker axle.
311189
Discussion Starter #84
I installed the front trail camera a week or so ago. Mounted it on the under-side of the center loop.
The camera is adjustable.
314565
The tip of the Smitty-build winch shackle is view-able.
314566
I'll install the rear trail camera when I figure out what will be installed back there.
Lookin real good there.
Nice! What are you using for a trail cam?
I've considered something like this, but my wallet keeps saying I've never needed one before why spend the money now. Can you record with it like a dash cam? That'd be nice dual functionality in event of something happening and needing recorded footage.
81 - 86 of 86 Posts
