1 - 2 of 2 Posts
If you actuate the diff lock switch (in 2Hi or 4 Hi), the diff lock light flashes and the ABS light illuminates. Is this just informative or does it disable off the ABS?
With the e-lock mod, you can engage the diff lock with no ABS light.
Maybe I'm behind the curve on it but could this be a solution to the off road ABS problem?
1 - 2 of 2 Posts
