1 - 8 of 8 Posts
Does anyone know which side is the shorter axle shaft? Driver or passenger? And even better does anyone know the length of each one?
I have a spare set in the garage. I'll go measure. Hold please....
You are a lifesaver!
Can't remember which side is the shorter but I thought it was the driver's side?
Short shaft = 30.5" from flange (wheel mounting surface)
Long = 31 3/8" from flange
Need any other measurements?
Awesome thanks! Can you give me one measurement from end of shaft to the bottom of bearing? I'm getting 26 1/4
To the bottom of the bearing or the swedge ring?
To the inside edge of the bearing I get
short = 26 7/8
long = 27 11/16
To the inside of the swedge ring I get
short = 26 5/16
long = 27 1/8
Subtract 1/16 from each if you want the inside edge of the snap ring land instead of the swedge ring. That would give you your 26 1/4, 27 1/16
Just the shaft up to the ring
Do you know if that bearing changes over the years? Or if the m226 always used the same bearing
1 - 8 of 8 Posts
