ABS Wheel Speed Sensor
Edit: NOT REGARDING THE E-BRAKE
Recently I installed the Nisstec extended travel lift kit. It came with longer brake lines, but my issue is from the ABS line. When I am fully flexed in the rear, my ABS harness is getting strained and acting as a limiting strap on the rear passenger side. Do any of you know of a bracket mod that may give a little more slack on the cable? or even an extended cable?
Thank you!
Thank you!
