Within the past couple hundred miles, when idling, i can hear from under the truck near the engine ... a tick tick tick tick that is in correspondence with the RPM, if I bring the rpm up to 1000 rpm the click speed rises with the RPM, this click is not at all very loud, pretty faint (this is when I'm leaning down outside the truck listening for it), once I get past 1000 rpm or so, I can't really hear it at all. i have no performance issues, nor is it burning oil at all, oil level is good.
Last oil change is 3200 miles ago... I plan on changing it before my next drive.. Does anyone else's truck tick a little when due for an oil change? .. What's your guys' recommended oil in the cold central Utah winter that isn't going to break my wallet ?
Im @ 28,000ish miles. No sign of bad timing chain guides... thank god...
Thanks a ton..
-steve
Thanks a ton..
-steve
