I'd be interested in the answer to this too...Has anyone put a power seat from an LE into an SE? The lack of lumbar support and poor seat angle is aggravating on long trips. Since the LE and SE seat material matches on the '07, I was hoping someone might have done it.
looking for heat mostly but power would be cool too. was heat only in the leather seats or cloth too? where'd you find your seats?I have installed a set of the leather/power seats from a 2006 LE into my 2007 crew cab SE. the seat base bolts exactly to the existing holes in the floor. i wired in a 20 amp dedicated fused (circuit breaker) power supply from the battery into the cab and to each of the seats (you need the factory shop manual to decode the seat wiring in order to hook up the power correctly). the air bag sensors, etc., all connected directly to the existing SE wiring harness. I still haven't hooked up the seat heaters but will get to that eventually.
How much trouble was the wiring? I was just considering the same putting SL or P4X seats in my SV with heated seats...Finally got my seats installed. Seat seams to go back further and I can pitch the front of the seat up to support my long legs.
I really like them and they seem a little more comfortable to me.
This would be to power the seat mechanical correct? Are the seat heat and air bag items on their own plug that plugs up or does anything need re-pinning etc?I direct wired them to the battery with a fuse.
Thanks for the info. The last time I did a seat swap was 89/90 and there was no wiring in those days...I did not run anything for the seat heat. The Airbag and the seat belt warning were both plug and play. I did have to reset the airbag lite after I finished because I disconnected the battery for the install.
