1 - 13 of 13 Posts
My drive shaft is huge maybe 4 inches, then there is a short piece with about 1.5 inch diameter that actually connects it to the rear diff, is this normal? See pic.
2016 CC LWB
Sent from my SM-G950U using Tapatalk
Are the short beds like that too?
No sir .... You can get a one piece drive shaft replacements ... there are varying opinions on doing so
2016 CC LWB
Yes that is normal and correct. That is a CV joint and not a U-joint. Xterra has the same thing.
That large diameter part is a hollow tube. The small diameter is solid steel. The hollow tube is better for carrying the power over distance. The small shaft is needed to mate with the CV joint so the axle can move and still receive power.
It's my understanding that the M226's got the stronger u-joints and the C200's got the weaker CV joints. Also only shortbed crewcab 4x4's and longbed kingcab 4x4's got a 1-piece driveshaft and every other configuration got 2-piece driveshafts.
You can replace the 2 piece with a one piece driveshaft (which is what I'll do when I lift my truck higher) however you would have to sidestep 2 issues. The crossmember that held the carrier bearing would have to be modified or removed cuz it would be in the way of a one-piece. Also there are limits to how long certain diameter steel driveshafts can span without deflection. Your driveshaft maker will have to specifics on that. But in general as the span (length) of a steel driveshaft increases the diameter of the pipe will also have to increase...and hence so will the weight of the driveshaft.
To overcome that issue, the better option is to get a large diameter aluminum driveshaft. It will resist deflection at the larger diameter and will be light as well. Only con there is price...but probably still somewhat competitive with the price of a new 2-piece.
2016 CC LWB
Mine
2016 CC LWB
2016 CC LWB
Mine was really bad
Automotive tire Wood Automotive lighting Fender Gas
1 - 13 of 13 Posts
