1 - 3 of 3 Posts
Does anyone know if there is a difference in the rear o2 sensors (B1S2 vs B2S2) on a Gen 2 V6?
I know the connector is slightly different, but is the pin out actually different or the internals of the sensor?
I ask because i can buy a right connector for $34, but the left is $100. I can easily modify the connector to work ie: grinding off the extra plastic on the clip to make the connection fit.
The internals wouldn't be any difference, but I'm not sure if the wiring pinout is the same (it probably is, but I'm not 100% sure). You can get the left downstream sensor from Rockauto for $73 (NTK brand).
1 - 3 of 3 Posts
