1 - 4 of 4 Posts
So I know how it works. Two wires at the dome light. There's a constant fused hot, and the other wire is a ground that when each door jam is open it completes the circuit. Then for the additional manual on/off switch the dome light changes grounds and grounds itself to the screw bolting it up, a body ground.
Now here's what I need to know:
Where can I access this main ground wire from each door jam when they are all joined to the single wire that runs up along the roof?? I want to tap into that wire at a convenient place not up in the roof.
I need it because I'm adding aftermarket interior lighting and I want to use the same ground circuit as the dome light, coming from the door jams, but I don't want to tap into the wire on the roof!
Thanks
The room lamp wiring travels down the A pillar to the SECU on models with power door locks and straight to the fuse box on models without power door locks.
1 - 4 of 4 Posts
