So when I was having to deal with the flat tire episode, and the subsequent moving of spare to wheel. I happened to noticed my rear diff looked a bit off.
This picture doesn't do it justice, there is a lot more than it shows and it is very sloppy. My question, do the differentials standardly come with this much sealant/gasket maker on the drain plugs from the factory, or do you think muscle headed gorrilla-von-hobo decide to strip the threads and then use extra RTV sealant/gasket maker to cover up the mess?
I have not yet checked the drain plug, but as it stands I don't think I should mess with it without having a spare cover to install.
Edit: changed to the correct axle type thanks bngnx4!
Your thoughts, and also does anyone have any good recommendations for replacement rear diff covers for stock C200K rear axles? Preferably for a reasonable cost.
