Status
Not open for further replies.
1 - 2 of 2 Posts
Webwheeler Extraordinaire
In an effort to clean up this section, we will be posting links to "sticky worthy" threads in here. Just click on the link to the DIY project that interests you and you will be taken to the actual thread. If you see threads that should be included in this sticky, please PM a mod with a link and why you feel it should be added.
Maintenance
shinermiller's Changing Automatic Transmission Fluid in a 2nd Gen
shinermiller's Changing Differential and Transfer Case Fluid in a 2nd Gen
HarshReality001's Changing the Oil in your 2nd Gen
Nismo54's Trip Computer Test Function
shinermiller's How to change spark plugs in a 2nd Gen
PCV Valve Replacement - 2005+ VQ40DE
Advan's Water Pump Replacement Thread
Repairs
Inyourface1650's Replacing a Fuel Sending Unit in your D40
HarshReality001's guide to changing the alternator in your 2nd Gen
Donahue57's Belt Tensioner Replacement Guide
codemaster01's Charcoal Canister Solenoid Valve Fix (Code P0455)
Zero Six LE's Automatic Transmission/ Radiator Bypass and/or ffips's Automatic Transmission/ Radiator Bypass
DIY Axle Seals/Bearings - M226
cd85233's How To Change a Window Motor and Regulator
Snowdrop's Replacement of the Spiral Cable (Clock Spring)
JeniorNV's How to Pull Code for SES Light/CEL without Code Reader (2nd gens)
JeniorNV's How to Replace or Check the Blower Motor
JeniorNV's How to Replace or Check Front Body Mounts
Advan's DIY Radiator Replacement
Suspension/Axles/Wheels
Shinjari's PRG Spacer and Deaver AAL install guide
tha_reids' 2" body lift install guide
chinaman's How to Paint Wheels
frontpagenews' UCA Bump Stops install guide
How To-Replace Up-Armored Humvee Shocks and Springs
stevet47's Rebuilding your Leaf Springs guide (also gains you 4" of lift)
badbrad358's 2nd Gen Rear Axle Vent Mod
Jagger's Nismo e-Locker Mod
M226 Diff Lock Override
fox294's Comprehensive Front Lift Installation Instructions for 2005+ Frontiers
dan826's Titan Swap How-to Video
Performance
steve396's JBA header install guide
shinermiller's NISMO 350z thermostat swap
Exterior
CanadianEH's 2nd Gen Hitch install guide
steve47's Converting Hella 500s to HID
dcobb's Dual Halo Projector LED Headlights
EB_05_Nismo's Hitch plug relocated to bumper guide
TysonCook's Utilitrack with Unistrut - D.I.Y.
begleysm's Strut Channel Install Guide (Homemade Utilitrack)
DeathByStereo's Homemade Utilitrack Tie-Down Points
Mylt1's fog light by-pass mod
Grill Removal step by step (05-08)
collinsz'sThule Roof Rack Install
Interior
CraneWR's Inverter under the Front Seat
delman's Cruise Control install guide
Gentex 50-GENK2A Auto Dimming Mirror Install with Lots of Pics (56K WARNING!!!!)
glamisdude's Comprehensive Audio DIY Research/Install Guide
glamisdude's HOW TO: Eliminate King Cab Door Rattle
Electrical/Electronic
Programming a key FOB to your truck by Jack
Reset TPMS Warning By Yourself - IT WORKS!!!
DIY Utilitrack
1 - 2 of 2 Posts
Status
