Background:
I have a 1st Gen 2000 Nissan frontier 4cyl 5spd. 75% of the time the AC would blow cold air. Occasionally the AC would stop blowing cold. After reading through several threads I discovered that the Thermal Control Amp is known to go bad on a few Nissan models from the earlier years. I ordered a new Thermal Control Amp from Courtesy Parts. Here is the link Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com. I read that there is a two wire and three wire version of this part. Please confirm which part you need before ordering.
This is the troubleshooting guide for the Thermo Control Amp from the Service Manual.
This is the location of the Thermal Control Amp as shown in the Service Manual.
Here is the part I received.
The only tools needed were a philips screw driver and a flash light. Here is the Thermal Control Amp unpackaged.
The first thing you must do is remove the glove box. There are a total of six screws holding the glove box on. Remove the two bottom screws here.
Remove the two top screws here.
The two latch screws are the last two holding on the glove box. You may want to support the glove box with one hand while removing these.
The glove box should now be free to remove.
Find a place to sit it on the side along with the screws so that they don't get misplaced.
The Coolant Unit Case should now be easily accessable.
Here you can see the old Thermal Amp Connector.
Remove the thermal Amp Connector by pushing in on the clip and pulling down. Be carefull not to force things here or it may break.
Remove the old Thermal Control Amp from the Cooling Unit Case by pulling down while lifting the top away from the Cooling Unit Case. Again be carefull not to force it too much or it may break.
You must now open the Cooling Unit Case to get to the old Thermal Control Amp. There are five screws holding the bottom of the case on. The bottom left screw is hidden and harder to access. First remove the four screws easiest to access.
Here is a picture of the hidden screw from below. It can be accessed with a long philips screw driver.
I did not completely remove the bottom of the Cooling Unit Case but I was able to finish the job through the space available. You may want to get a long needle nose pliers or some type of grabber tool to remove any built up leaves and debris.
There is an Evaporator Core inside the Cooling Unit Case that has fins and looks similar to a radiator. Here you can see the old Thermal Control Amp sticking in the side of the Evaporator Core. I squeezed the blue flashlight between the top and bottom half of the Cooling Unit Case to keep it open and illuminate the inside.
I was able to squeeze a few fingers inside the Cooling Unit Case to remove the old Thermal Control Amp from the Evaporator Core. The long plasitc piece protruding from the side of the Thermal Control Amp sticks in between the Evaporator Core fins. Grab the old Termal Control Amp and pull it to the left to remove it from the fins.
It is now time to install the new Thermal Control Amp. Once you have it inside the Cooling Unit Case try to stick the protruding plastic piece between the Evaporator Core fins. It will take a little time and patience. I was not able to get it installed as far back as the origional Thermal Control Amp. Hopefully that will not matter.
The new Thermal Control Amp is now installed. Feed the extra wire out the notch in the case.
Install the new Thermal Control Amp into the clip on the bottom of the Cooling unit case. Plug the bottom wire harness into the new Thermal Control Amp. You can use a little electrical tape to keep the excess wires safe.
Repeat the Glove box removal steps from above to reinstall the glovebox. All Done!
So far this fix seems to have corrected my problem. Time will tell. Now someone please go make this a sticky. Feel free to add comments, suggestions, complaints, etc..
