I did an SE 6 speed... I drained it, unbolted everything that was in the way, put the new one in and bolted every thing back up.. I know not lot of help.. it was a couple years ago.
Remember that if you go by the book, the cooling system in the Gen2's requires that a vacuum be pulled on it during the coolant fill so as to eliminate air bubbles, as there are no bleed screws on the block. Members have dealt with this hurdle in other ways to their satisfaction.
I think that is just for auto, I never did..
Nizmut and I did in a couple hours.. It took longer then we thought it should.
