Hi
i have a 2006 V6 6speed SE crew cab with 200K miles
the diff is wining and i need to replace it
i found that he pinion was loose and even after several attempts to snug it the noise is there (it has a special way to tighten it)
also have had to replace axle bearings several times on both sides.
what years will swap into this truck?
does it need to be manual?
will a 4x4 diff work?
thanks
thanks
