1 - 3 of 3 Posts
I have a 2007 nismo , king cab,
I want to source out a differential flange, Nissan says they are unavailable for my truck.
They gave me a story about because it has an elocker they can't get a flange for it. I have a hard time accepting this.
Here is what I can tell you
2007
Nismo
Automatic
Four hole flange
Driveshaft has ujoints (as opposed to cv joints)
Elocker
M226 axle
I don't know if the spline is 24 or 29
My pinion seal is leaking again for the 3rd time, so I feel I should source out a new flange
Can anyone help me , as in Nissan parts number that will work, or company that sells these flanges.
Thank you
Ken
Discussion Starter · #2 ·
I have a bit more information.
The companion flange is a 24 spline. There is quite a groove wore in the shaft , so I am thinking a new companion flange or maybe a speedi sleeve.
If I order a speedi sleeve, does anyone know the diameter of the flange shaft.
I tried google but I can't find it anywhere.
Thanks
search speedi-sleeve. It is a repair kit for your old flange. I've used them when the replacment part is hard to get or very expensive. It is a thin sleeve that is a press fit over the damaged sealing surface. Don't worry about the overall diameter being slightly larger, it works.
1 - 3 of 3 Posts
