1 - 2 of 2 Posts
Good Day to Yall! OK, so I have this 2007 2wd nismo Frontier, its actually my Sons truck. Anyway, the truck came equipped with a locking rear differential. Diff lock light in dash flashes when vehicle is started.
Evidently while the previous owner had the truck, the wiring harness that connects to the rear end, got ripped off. If im not mistaken, there are 2 plugs that plug into the rear end. One of the connectors that plugs into the housing actually broke the internal part of the connection. Mechanic told me that the gears actually have to be removed to make this repair. Any information on this issue would be greatly appreciated.
The position switch is the one that requires the axles and gears to be removed in order to change it.
The truck should drive around just fine as a normal open diff forever in the condition it is in (so long as fluid stays in and water/dirt stay out).
1 - 2 of 2 Posts
