This post isn’t so much of a “rant” but just to say “why?” - the stuff that dealerships like to “fluff” when you’re in for service sometimes is mind blowing.
Sooo... went in for a 15k service today - Oil Change and Tire Rotation is all I needed (currently in a apt so not a good access to a garage so the dealer does these for now). While I’m there the clerk asks me - do you also want our “15k service??”.
What’s that I asked and how much? He proceeds to tell me “it’s $309 and includes several needed things”.
Ok - I’m interested... WHAT things?
Well sir - we flush and fill your brake fluid, perform an alignment, replace the air filter, replace the in-cabin micro filter and key fob battery - plus you get your oil change and tire rotation.
All that for $309? Yes sir!
Is the alignment out? No but it’s recommended.
So the factory didn’t align it right and it needs to be done? No - it’s just needed to follow the recommended service.
That’s not listed in the manual? Well sir - we recommend.
What about the key fob - it works fine? Yes - but it’s recmmended.
What about the brake fluid flush - does it leak? No - but it’s recommended.
Why - do you expect it to fail? No it’s just recommended.
Sooo - out of all that the ONLY thing in the manual at 15k (other than oil/tire rotation) is the Key Fob Battery and In-Cabin Filter. I’ll buy a filter at AutoZone and save $50 - the Key Fob threw me though. If had the one for my 2013 Explorer since I bought it... still works fine? WHY would I replace it (for $75!!!) at 15k!
I politely told the clerk “I’ll pass” and will replace the micro filter when it goes bad along with the key fob - my air filter is pristine so I’ll be good for awhile on that. Most cars can go their lifetime without a brake fluid flush - so I’m good for there. Alignment? Unless the tires start to wear bad or I notice it pulling - I’ll pass.
However what angers me is how many people will pay for that without thinking because someone “recommended” it... sad.
I doubt anyone on this board would be so easily duped - however if you’re one who will pay for whatever the service dept. says you “need”... don’t say you haven’t been warned!
