I've been using these and have the following issue: They seem too bright and can't be aimed correctly!
I get flashed every so often (a lot of 18 wheelers...). The beam pattern seems very spread on low beam, but only gets slightly higher on high beam. The result is that I can only aim them one way so that I have a high beam; otherwise, I aim them too low and my high beam is too low and becomes more of a brighter low beam. This way of aiming seems makes the low beam too high and too bright.
Has anyway else had this problem? I am almost wanting to plug my halogens back in to avoid getting an improper equipement ticket... or getting 35w 6000k (or lower).
Maybe this is due to the newer/more spread reflector design on the new 09+ headlights?
BTW, 55w 8000k is like an light teal color... I would say a 7000k 35w (not 6000k).
