Hi Guys, I know a lot of you have upgraded your front pads. However I think that a front and rear brake upgrade would be a far better idea. So I have been on the search for information, but to no avail. So I dug further and found out that the R51 Pathfinder has the same brake booster but different master cylinder to the D40 Navara. So that should be easy to change, allowing us to fit Pathfinder rear disc systems. It seems that a vehicle with drum braked rear, pumps more fluid to the front and less to the rear. While the disc all round pump evenly front and rear. Interesting fact is that a disc/drum system pumps more to the front than a disc/disc system. This maybe part of the reason, the front brakes on the Aussie Navaras cop a hard time?
Does anyone know what diameter our fronts discs are? As I found this website that lists two sizes. Japanese Import Car Parts
please scroll down to see them. Also on the lookout for an aftermarket 4 pot front system with an upgrade to a two pot rear disc system.
:itsfriday:
:itsfriday:
