1 - 9 of 9 Posts
Has anyone cut their stock exhaust back to keep it from getting bent up and to increase the rear clearance at all? If so, did you have any issues with the spare tire potentially getting too hot? That is the thing keeping me from cutting it back right now.
If you have done this, do you have any pictures or locations of where you cut it?
I know AFE makes a high clearance setup but I like having a quiet truck for the time being ::smile::
Thanks for your help!
Um, you're in Colorado, eventually you will have to have an emissions test, that shorty exhaust will probably be a fail, as they won't be able to access it for the "sniffer". I took mine to Exhaust Pro's, they did a custom cat-back for me that tucked the exhaust up as close to the bottom of the truck as possible, high over the axle and close to the rear mudflap and tight to the body. Since I have a long bed, I'll likely tear up body panels before I damage the exhaust.
Initially had mine cut where the others have but I starting breaking hangers for some reason... After a had 2 hangers break I took it to a muffler shop and had them cut it just after the muffler and reuse the factory resonator and chrome tip in a turn down setup.
1 - 9 of 9 Posts
