1 - 16 of 16 Posts
I just love making things with wood!
These little boxes are clearly not perfect, I can find all sorts of things I could have done a bit more perfectly, but in the end, they are what they are, and they will serve their function very well, as they are.
The materials I'm using
• 0.188" plywood for the bottoms
• 0.75" clear pine, planed down to be 0.5" thick for the sides
• 0.75" clear pine, planed down to 0.375" and 0.438" for the corner and bottom supports
• #6 wood screws, 1", 0.75", and 0.5" long
• Titebond wood glue
The first things that needed a place to get stored is the utility track clamps, bungie cords, and rope. This is the part I love, figuring out the best way to make it so I can use all the space I got to the best of my ability.
The first box made was the simplest, it just fits under the drivers seat, it's made to fit into the notch of the floor so it could be as deep as possible. I could have made this about 1.5" wider, but then it would have had to go on top of this floor bump, which would have made the box shallower than what was needed.
Here is the first box, very straight forward, it is designed to hold rope and the utility track clamps. The hole by the way is a finger hole, so I can pull it out from under the seat once it has been inserted into its space.
The second box took twice as long to make, and it is way smaller, but way more complex. This little sucker fits right into the space under the rear jump seat, when the jump seat is folded up. The box is not very wide because there was only about 2.75" of space on the little shelf under the seat. The weird projection in the back is made to fit right into a negative space under the seat, in the area that is not taken up by the seat hinges, and the slots in the side, well they allow the box to sit all the way back and the seat hinges protrude into those slots. This thing is made to fit so tightly that once it is in place, it is held in space by nothing more than friction, it's a snug fit, but that was needed to get the most storage space out of the small area I had to work with.
Here is the second box, it is designed to hold a mass of bungie cords. This morning I was able to pack more than a dozen of them into this thing, and the weird shape at the top, the protrusion worked great because it gave me enough extra space for the bungie cord's big metal hooks I had room to stuff even more cords into the box. So all the time I spent to make that little bit of extra space was well worth it.
More pics to come of them painted
More pics to come of another whole new 3rd piece
Banned
Nice handy work there. That is some nice looking underseat storage compartments.
Instead of bungee cords, how many tie-down straps can you fit in there?
I have found that bungee's just end up breaking or stretching out so I only carry tie-downs (4 pull tight and 10 ratcheting).
Also, since you have a KC, have you found a place where you can put a tarp? I know in the CC you can put it behind the rear seat when you fold it forward but in a KC I have no clue.
Discussion Starter #7 (Edited)
Yup, painted and in pics to come, 1st coat of paint is drying now....
I have to hit Home Depot/Lowes tonight on the way home, I want to see if I can get a really dark grey so I'm close to my interior color.
The tie-down straps will be going into the storage box that goes under the passenger's front seat. Most of the time I just need bungies to keep lumber from sliding around so they are on the driver's side where they are the easiest to get to.
BTW- what the hell, I just noticed this morning there is not a single F'ING strap hook screwed into the bed, the utility track is the only thing. The Titan had one little hook on both sides way in the back of the bed by the tailgate edge, they were so handy. I can't believe I don't have those anymore.
Why would I need a tarp?
I have the awesome LazerLite tonneau cover on order.
Check it Trip:
http://www.clubfrontier.org/forums/f23/diy-utilli-trac-tie-down-points-41784/
or
http://www.clubfrontier.org/forums/f10/cheap-tie-downs-cleats-utility-track-32090/
Some crafty peeps on here that's for sure.
Discussion Starter #9 (Edited)
So I just stated I have another to build forunder the passenger's front seat, that will be a lot like the 1st one pic'ed, very simple.
The 4th one though, I started this last night, and I'll admit, it might be a crazy idea, but I'm going to build it, and see if I like it.
The Titan spoiled me with space, and it too was a KC. The rear seat on driver's side was always up, so I had full use of the floor, the passenger's side rear seat was always left in the standard seating position, and when I opened my side rear door I would toss my backpack on the floor, and my coat and hat onto the seat.
In the Frontier I have kept both back seats folded up, but I just don't like tossing my coat in on the floor. So I tried putting the passenger's side rear seat bottom down, but whenever I put my coat on it, because it is so small it would always fall off, and be right back on the floor. Grrrrrrrrrrrrrr.......................
So, the idea is, make a box that is the full dimension of the floor space on the passenger's side rear seat area so it will actually have a bottom size bigger than the seat bottom, and make the side heights two levels so I can fold the seat botto down over part of the box, and when I put a lid on the rest of the box, I'll have a platform the height of the rear seat, that takes up that entire foot well space.
Hard to describe, more pics to come as I continue my builds...
Check it Trip:
Yea, I'm going t have to do that, it will be a bit better than nothing, but not as nice as those darn Titan hooks. What I liked about them is they were bolted to the side up off the floor, on the bed surface that is sort of like the back side of the tail lights. They were totally out of the way, and yet super handy.
The things I'll have to make for the utility track will have to be down on the floor in those rails, and I'm sure they will be in the way 50% of the time...
I should formalize my Titan versus Frontier list, I love the Frontier, and am thrilled with it, but damn, Nissan really stiffed us on some cool features all the Titan have.
You can order the stationary tie down points and just install them yourself. I did this for my CC. I'll go and check and see if I can find a PN for you.
Also, there is a thread on here in which a member confirmed the tap size that is needed to be used since the holes have bedliner in them and then a plastic plug over the holes.
I believe the PN for the hooks are 93806-7S200 and they come with the bolts. I thou did find a way to strip a bolt and also didn't know they came with the hooks so I order 8 extra and their PN are 01121-0051U.
I would double check these before just blindly ordering them but these are what you need.
Also, since you are into woodworking it may behoove you to do the 2x6 plank mod so that you can fit full sheets of plywood in the bed without having them hand out the back too much.
Lastly, if you think you can just put a couple of sheets of ply in the bed and rest them on the tailgate while it is up, you will end up bending your hindges. A member on here did that and was amazed on how weak the hindges really are.
Discussion Starter #11 (Edited)
To the mod who moved my thread:
Thanks. I'm sorry, I guess I have to get better about thinking outside of the General Discussion box.
Here is an update on the weird little box...
Weird little box in its environment
Weird little box Installed
The fit is so perfect it is snug, and no matter what, does not seem to budge, so it stays in place, and makes no noise. I'm not happy with the grey color, the match is better in the pic than in real life, the color is just too far off for a dark grey, it looks like it is trying to match, and can't. I'll put the final coat of paint on it tonight and will be going with black which I think will be the best option as I'm not spending a ton of time trying to find a perfect dark grey match for the seat fabric/carpet.
You can order the stationary tie down points and just install them yourself...
:bow: Dubie
Thanks for your entire reply!
I'll have to crawl in there tonight and take a closer look, if its like you say and the holes are there with plasctic plugs in them I'll for sure make this mod.
It's kind of funny, I was already thinking last night about dropping into the Nissan dealer and ordering the Titan hooks. I figured once I had them I would take the leap of faith and drill into the bed, but it sounds like it might be even easier.
Looks great, nice work mang.
Discussion Starter #15 (Edited)
Now I have to figure out what to do with the floor. I don't want that OEM plastic bin there, but I hate the fact that when there is no mat on the floor you see the red metal brackets that the plastic OEM bin clipped into. Why in the hell did Nissan have to go and cut holes in the carpet???
I guess I need to go buy some smaller mats, the one in the pic is too big, and I can't get the under seat tray in and out.
Thanks for all the compliments, I'm happy with how this one turned out for sure.
Look for more new pics on Monday :)
1 - 16 of 16 Posts
