Ok, so I searched high and low and no one makes a aluminum diamond plate tailgate protector. So....I decided to build my own. I wanted this protector to be a complete bolt on project because I might mass produce these if I get enough inquiries. My protector replaces the old style black plastic cover (pictured 2005-2007) and the new style black plastic cover (not pictured 2007 to current).
Details:
-1/8" thick aluminum diamond plate
-rounded inside corners
-sits flush and right up against factory top tailgate protector (black plastic one)
-12 recessed 1/4" stainless steel screws (included)
-12 1/4"x20 jack nuts (included)
- spacer washers (included)
Install steps:
1) remove all hardware from old black plastic protector and remove protector
(The top of the old protector has double sided tape all the way from left to right so a paint scraper works great to pry your way across)
2) elbow grease time: use a plastic scraper and rubbing alcohol or Goof Off and remove double sided tape from the tailgate. (Now is a good time to clean the rest of the tailgate)
3) remove and set aside upper access panel (it only goes on one way and it is directional)
4) remove nylon square nuts from sheet metal
5) get your drill and a 7/16" drill bit and CAREFULLY DRILL out the 8 square holes you removed the nylon square nuts from. (If you are not careful your drill bit will dent the other side and leave a little dimple showing on the outside.....I did this on one hole! Haha)
6) now drill out with 7/16" bit the lower 4 holes closest to the bumper
7) insert 12 jack nuts and proceed to sandwich them in place. (Please watch how to videos on YouTube if you are not familiar with properly installing jacknuts)
8) place access panel back where it goes
9) install spacer washers at all 12 holes
10) set aluminum diamond plate protector where it goes
11) install 12 stainless bolts but leave loose until all 12 are threaded in by hand
12) tighten bolts by hand starting in the middle and working your way to the outside. Once they are all snug, using an 1/8" drive INCH pound torque wrench (NOT FOOT POUNDS PEOPLE), torque them to 35 in lbs.
13) wipe your sweat and finger prints off with warm soap and water and ENJOY!
Thanks,
CPS
Before (more pictures to follow):
Details:
Install steps:
Thanks,
CPS
