21 - 40 of 99 Posts
Ok, my take on it. The truck has 200,000 miles on it. Even if you do the work yourself, you're looking at hood, bumper, front crash bumper, possibly replacing the front frame extensions, the structures behind the grille that retain the grille, headlights, and the upper valence, plus trying to bend-out the radiator core support if it isn't modular, plus all the sensors that you've crushed and possibly replacing wiring harness ends. you also have to confirm the situation with the transmission cooler, power steering cooler, and HVAC condenser.
In your shoes, I'd look for an SV or Pro4X from the last five years and transfer over any modifications or upgrades. Probably have an axle shop go through the rear end with locker and swap it in, depending on gear ratios do the same with the front differential.
Unless you found a full donor truck with the same paint color I don't see you doing this cost-effectively even if you do all the work yourself.
Discussion Starter #24
I think the 05 has a radiator core support that is modular I have quoted the modular steel frame and it’s cheap.And why are you talking about drivetrain..There should not bear any damage on the front drive train that’s nonsense.
The airbags didn’t go off which is a good thing I hear they are expensive to replace lol
Glad you are ok! you can always get another fronty.... be well brother!
Or...
unbolt the bent stuff, hook a come along to a phone pull and the core support, bend it back in place, bolt your parts on and adjust for fit, Rattle can it a close color, crack a beer and relax....
Cut your losses and move on.
Sorry to see that. On the bright side the frontier held up pretty good. Good thing is gen 2 frontiers are a dime a dozen. I remember in a response to something I posted you wanted a 6 inch lift. You might want to consider getting a newer less damaged truck. It’s hard to tell, especially on newer trucks how much is actually damaged. If it seems to damaged you could either save it or sell it as a parts truck. Sometimes if the vehicle is a certain age they will let you keep it. Good luck.
A hydraulic puller, pull back ram, some chain, come along & a couple trees not too far apart from each other will do the trick... as long as the motor and tranny are still good.
You hit a pole cause the sun was in your eyes.
WTF!!
If you CAN'T see you shouldn't be driving forward. What if it was a HUMAN instead of a pole!!!
How often do you use the "can't see ****, hope there's nothing in front of me" approach when you drive?
Discussion Starter #33 (Edited)
WTF!!
They call this city the sun city for a reason here we have rays as strong as australia 365 days a year.This isn’t the coast this is west Texas!
Discussion Starter #34 (Edited)
I was going at least 15mph to a dead stop! How much pressure you think there was I figure at least 1 Ton the damn pole didn’t budge.
They call this city the sun city for a reason and here we have rays as strong as australia 365 days a year you numb nut.This isn’t the coast this is west Texas!
How many people do you know or how many stories have you heard of people in your city (El Paso) driving directly into a pole in a parking lot???
Great truck
Just hook to a tree and put it in reverse.
21 - 40 of 99 Posts
