Might be worth seeing if the seller will ship?
Nissan Frontier truck bed utility load tie down system with rails with adjustable tie down hooks. Fits a double wall truck bed that is 58" X 58" or larger. Works with bungees and cargo straps to secure your loads.
Utility Track Truck Bed Tie Down Rails and Accessories
The rails don't just bolt on though. There are welded mounting spots.
True if you want to mount them on a truck that did not come with them.
I bought some off of CL years ago and bolted them to the bed of a trailer. Worked great for that.
The utility rail on our trucks is essentially glorified uni struts; an industrial standard. All uni strut hardware will fit into our rails. If you want to set up a rail system in a trailer or such, you can simply buy length of unistrut at home depot or any industrial supply shop. I just did a quick search and here is one ol boy setting up a rail system in his tundra.
home made bed rail system - TundraTalk.net - Toyota Tundra Discussion Forum
